I have a problem when you go to start the only light that comes on is the normal wash and just blinks will not start any suggestions
Replacement parts for KENMORE 66513819K600 | AppliancePartsPros.com
If you need a parts breakdown there should be on Sears Parts site.
Here is the tech sheet, see the attachment.
Try running the diagnostics to see if any additional clues to the cause come up.
A blinking light is often a shorted key.
This could be the keypad or the control pad.
The keypad keys have to be checked with a meter.
If it checks out OK then I would replace the control board.
Still a bit of a crap shoot but your odds are better.
KUDP02.pdf (250.6 KB)
