Dishwasher
Dishwasher has no power due to tripped breaker. Breaker will not reset. What should I check for
Breaker!
Unplug the dishwasher and check the breaker.
Disconnected wires and reconnected and breaker still tripping. Is the motor bad?
Are you able to reset the circuit breaker while the dishwasher is disconnected?
Probably you have to call an electrician to check the breaker itself. Circuit breakers can break too.
