Dishwasher
Why does my hose keep comming off?
Do not know what hose you are referring to?
Replace the clamp with a screw type hose clamp.
Here is an example
Northern Industrial Zinc-Plated Hose Clamps � 34-Pc. Set | Hardware Kits | Northern Tool + Equipment
[quote=denman;161091]Do not know what hose you are referring to?
Here is an example
Northern Industrial Zinc-Plated Hose Clamps — 34-Pc. Set | Hardware Kits | Northern Tool + Equipment[/quote]
the hoses come in from the dishwasher to plastic that pop on the faucet:cool:
the plastic is on the top of the dishwasher hose and keeps comming off when i try to put water in it
Sorry did not know this was a portable.
Without being there I cannot say what the problem is.
Sounds like the connector to the faucet adapter is either worn out or broken.
