Can anyone help. My dishwasher is not getting hot and as it progresses through the cycle it seems to just be washing all the time and does not stop at the end of cycle. When I stop and open the dishwasher is cold and the contents are not clean. Could it be the thermostat as my washer is a cold fill. It is a counter top so it has only a small capacity. I have tried to clean with the distilled vinegar as suggested on a blog for another make of dishwasher, but to no avail. Hope someone can help me, Kind regards Elaine
read the thread above titled bosch dishwasher troubleshoot manual
and this one Bosch Dishwasher Stuck on 2H.
I think your symptoms fall in line with the ususal running on forever-water not getting hot-etc Bosch problem even though you have a different model number. I think it is the circuit board. On mine a solder connection was burned out. If you can look at your control module/circuit board you will be able to check if that is it.
I soldered mine and it is working again -for now.
