When the dishwasher get to the last minute of the cycle it does not stop the water keeps running inside, Do i need to replace the control board.. this is the 2end time this happend to this dishwasher. it is very expensive for a repairman to come out and charge for the parts and labor and the service call if i can do this myself I will, thanks Michele
I have a Bosch Dishwasherm when it get down to the last minute in the cycle it keeps running water, it does not stop to dry the dishes,Do I have to replace the control panel this is the 2end time this happend to this dishwasher so there is water in the bottom of the dishwasher..see my info on the message above,I hope you can help me to do this myself..thanks Michele
Looks like the problem is a bad control module and the correction is to replace it. If you know how to handle a simple tools then this job is not going to be very difficult. You can find the instructions attached to this reply.
- The part number for the control module is AP2802870
Here are the breakdown diagrams and Replacement parts for BOSCH SHU6805 UC/12 (FD 8003-) | AppliancePartsPros.com
How to replace control module.pdf (23.2 KB)
