Dishwasher Fills Up On 1st Cycle. Runs Through And Drains. Will Not Fill Up On 2nd Cycle. Add Water Manually (via Pan) It Runs Cycle, But Will Not Refill On Amy Other Cycles.
Could You Tell Me What The Problem Could Be?
Thank-you.
dje52rme@aol.com
Thank-you.
dje52rme@aol.com
Would it fill up if you cancel the cycle after the first drain and start it over?
We Did Cancel After The 1st Drain, And Restart Again From The Start. Unit Would Not Fill With Water.
Thanks For Suggesting
Gene We Went And Changed The Water Valve And That Seemed To Do The Trick. It Is Working Good Now…i Hope!
Thanks For Your Help
Dje52rme
I’m glad you were able to fix it. Good job!
