Leaking at left side bottom of door, replaced the door seal and still leaks. Did not replace the tub corner baffle’s (Have ordered them today also the dia. shows a gasket insert but I can not see one on my door. The seal has a gap at both ends on the bottom about 3 inchs not sure what should go there but there was nothing there all this time.
Model GSD5500G00CC
Take a look at item 845 in “1. section”
Also check that the float switch assy on the left side front of the unit is not the leak. Sometimes they get crud inside and capillary water causing a leak.
Also make sure your holes in the spry arm are clear, sometimes you can get a partial clog which sprays water at weird angles and causes a leak.
