Dishwasher
drain selonoid pulls correctly, water moves at end of drain cycle for 1 or 2 seconds only, motor works,water pressure is strong. please offer any helpful info.
I would say your drain solenoid is overheating, its trying to energize but giving up after it overheats, easy repair, drop down that front toe panel you will see it right there. Looks like a 2 inch round metal piston with a bar attached to it
