Dishwasher won't work
The dishwasher digital display keeps blinking some of the functions, I turned the breaker off and turned back on to see is this would reset the display but it keeps doing the same,let me know what i can do to fix it or I need a new display.
Cesar Bazan
First, make sure the electrical connections are sound and the polarity is correct.
I checked the dishwasher over the weekend as you recomended ,all electrical conections are sound and polarity is ok, I notice a lock icon that keep flashing too, i don’t know if that means locked but I tried pushing different ways but didn’t work. what can i do now?
Replacement parts for WHIRLPOOL GU2700XTSB1 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10130990.pdf
Sounds like a control board or keypad problem.
Try the connector cleaning below.
Try to run the diagnostics.
If all fails then the normal way to troublshoot is to check the keypad with a meter if it is OK then replace the control board. This is a bit of a crap shoot but the board itself cannot really be troubleshot.
CONNECTOR CLEANING
Unplug the unit
Open it up
Clean the edge connector.
