Dishwasher won't turn on
I’ve replaced the touch pad on the front of the dishwasher, and just replaced the control board inside, but my dishwasher still won’t turn on. Does anyone have any suggestions for things to check and/or replace?
Here is the parts breakdown
Model MDB6600AWW
Here is a service manual, a tech sheet and a troubleshooting chart
http://www.servicematters.com/maytag_library/docs/TDD-0008-S.pdf
http://www.servicematters.com/maytag_library/docs/16023212.pdf
http://www.servicematters.com/maytag_library/docs/16021814.pdf
The most common cause of a unit having no apparent power and not starting is a door switch not closing or the contacts in a door switch not closing.
Also check that the rinse aid has not been leaking and messed up the wiring going from the controls to under the machine.
