Dishwasher won't start
Brand: GE
Model Number: GDT655SMJ0ES
Main Symptom: Won’t start, did on occasional reset at circuit breaker, then no start at all
What happens & when: Replaced UI board and door latch from parts ordered at Appliance Pro, after turning on electric, lights that illuminated were steam and lower wash, could not select cycle. Pins were set to recommendation with new part. Figured it was lower control board, ordered and installed. Still have same issue. Called Appliance Parts pro, spoke to Michael who suggested we check harness between upper and lower boards. Did that, checked ok. Don’t know where to go from here. Is it possible to get a call from you? [phone removed] Debbie
Parts or tests already tried: upper UI board, lower control board, & door latch
