Dishwasher wont start
Help- My dishwasher won’t start- we’ve tested the switch, latch everything seems fine- the lights are all on, it just won’t start- should i replace the control board or the control panel
Parts for Maytag MDB7609AWW2 Dishwasher - AppliancePartsPros.com
The tech sheet is too big to attach in this site so I had to use a third party site.
Unclick the Use Our Download Manager and then download it using the grey button. Otherwise the site may put software on your computer that you do not want.
Download MDB7609.pdf
Does sound like a control board problem since ypou say all keys/lights are flashing at the same time.but I would try a couple things before replacing it.
Remove power from the unit for several minutes to see if it will reset.
You could check the keypad with a meter, see the tech sheet.
Perhaps try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
well that didn’t work-replaced the control board-same problem–lights do not flash just sit there for a few minutes ,then go off–what to try next?
Check the keypad with a meter, see the tech sheet.
Check the motor windings with a meter.
Check the motor’s start capacitor.
Check the door switch. The one that is connected to the motor and heater.
we’ve checked the door switch-- if we use the clear sequence (normal-heated dry-normal -heated dry–it will start but the start & cancel buttons are both lit–runs for about 10 minutes and then stops
Sounds like a bad control panel. Very common problem on these. If service mode runs through OK when you do the heat dry/normal/heat dry/normal sequence but you cannot start a regular cycle then the membrane circuit for the start key is bad. Replace the “console assembly”. That’s what they sometimes call the control panel. Be sure and order the right color.
thanks, we’ve ordered that part keeping fingers crossed!!
