I have blinking lights on the front of my Whirlpool dishwasher and it won’t start. I paid Sears to come diagnose the problem but the cost to repair it was more than what I paid for the dishwasher. Since I knew that we needed a control panel (according to Sears) that is what I ordered from you. My husband installed the new board last night, very easy, just plug everything in but the dishwasher still will not work. Don’t know if Sears made a mistake or if the board is maybe bad. Please help.
Here is the tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535451.pdf
Try to run the diagnostics.
Often blinking lights is a keypad problem, see the tech sheet for the method to check the keypad with a meter.
You could try the following but it sounds more like a shorted key switch.
RIBBON CABLE CLEANING
Unplug the unit
Open it up
Clean the edge connector.
Thanks very much for your help. We’ll give this a try.
