dishwasher will not do the heavy wash cycle or the rinse only cycle
Replacement parts for MAYTAG MDBTT60AWQ Dishwasher - Undercounter | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Schematic%20-%20W10179503.pdf
Try the diagnostics.
Since only 2 buttons do not work and it looks like there is no common connection which only involves 2 switches, it sounds like the control board is gone.
I would still check the control panel (keypad) switches with a meter.
Also try the cleaning procedure.
If the switches check out OK and the cleaning does nothing then odds are the control board is gone.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
