Dishwasher won’t fill and pump is loud
I have a Bosch mod. SHU3336 UC/14
I checked power to the control valve and starts out at no voltage and after about 20 sec. voltage goes to 120 volts.
I disconected the output side of the control valve and with 120 volts applied the water goes through the valve.
Any ideas…what do i look at next ??? ![]()
Thanks for any help you can give me…Angelo
