Dishwasher won't dry
My dishwasher quit drying the dishes. The water isn’t hot, and the burner coil doesn’t heat up. Water from the sink is 130 degrees. Heating element measures 17ohms, I just replaced the high limit thermostat switch and it still doesn’t work. Please help!
i just figured out my issue and it was the same as yours. I wanted to let you know what i found in case your issue is the same.
If you have a element fail or control board etc…, the dishwasher will disable the heating element circuit. Even when you install the new one, it won’t turn it on.
to fix this, you have to press any 3 buttons in succession 123123123. This will start a calibration mode and then reenable the circuit. Hope this helps! email me if you have questions. Check out this thread as well. mk2488@gmail.com
https://www.applianceblog.com/mainforums/threads/53857-WDT710PAYM5-New-Heating-Element-Not-Working/page3
