My Admiral dishwasher will not drain so if anyone out there might have a solution I would be very grateful. ![]()
We need, at least a model number for various research needs,
The model and serial tag should be located on the tub frame(opening),usually on the top or left side of the tub or door.
We can help better if you could get that for us.
I looked for the model and serial number where you suggested but was unable to locate it.
What next?
Unfortunately,
There’s not much more we can do.
Admiral had 3 or 4 different versions of dishwashers ( depending on age),and even one that was produced in another country.
Here are a few general things to check :
Does the motor run in the drain cycle ?
Do you hear a click noise at the start of the drain cycle ?
If you have a grille in the back center of the bottom of the tub, check and make sure there is nothing clogged or blocking the grille,or the sump under the grille.
Check the drain hose and disposal connection for clog.
(disconnect the drain hose at the disposal/drain connection, and drain water into a bucket).
That’s about as far as I can you for now.
Thanks for all of your help.
You’re welcome
Sorry, we couldn’t do more for you ![]()
