Dishwasher wont drain, all else works. When cycle is done there is still water in the bottom. Is the pump to blame and is that an easy fix or am I better off buying a new dishwasher??
I would check the drain hose … The air gap … and the garbage disposal for clogs before you assume it has anything to do with the dishwashers pump
Thanks for your help, how do I check the drain hose? I can’t see it from inside the dishwasher?
I have the same problem with a seven year old Frigidaire, I’ll check the drain hose and disposal.
OK, I started a new cycle, and the machine drained part of the water before starting the cycle. Apparently the pump is working, so what do I check next? BTW, Model Number FDBL960BB0.
