Dishwasher won’t run cycle
Brand:Maytag
Model Number:MDBH979SAM0
Main
Symptom:Stops mid cycle
What happens & when: have to push start button to restart
Parts or tests already tried:W10619006 Latch
Have been having problems getting my dishwasher to run a full wash cycle. I reviewed troubleshooting and told is issue with the latch causing cycle to stop and flashing.
I tried installing latch that was sent with order and started leaking water from machine.
Attached is picture of smaller latch that was sent with order. New latch is much larger. Please advise as dishwasher not running fun cycle and issue for working properly.
[quote=“Justdumond, post:1, topic:414830”]
MDBH979SAM0
[/quote](
You will need to call customer service and advise that the wrong latch was sent. You need (Whirlpool WPW10544004 Dishwasher Door Latch Strike | Genuine OEM Part) Tell them Technician Jeff S, said to warranty swap it
I tried the larger Whirlpool latch W10544004 that was sent. As can see from the picture it is larger than current W1040079.
Washer worked and didn’t interrupt cycle but didn’t seal and started leaking out the bottom of door.
Believe larger latch is not allowing door to seal properly with extra 1/2in in length.
SO neither latch is working properly?
Correct.
Old latch strike - does not run cycle and stops unless am pushing on door.
New latch strike - water drips out bottom of door.
I believe after discussing with a few other techs, that the problem may lie in your hinges
