my dishwasher will run through a complete cycle. then will continue running unless i open the door. took the timer out closed the door dishwasher still runs. whats going on.
its broken,
[QUOTE=waynemcd1;309160]took the timer out closed the door dishwasher still runs. whats going on.[/QUOTE]
If you’re dishwasher is running on a timer and you’ve properly removed this from the circuit, I guarantee you that it will not run.
If it’s still running after you’ve removed the timer, call ghost busters.
Your timer motor is shorted.
Replace the timer.
