Brand: Bosch
Model Number: SHXM78W55N/01
Main Symptom: Will not power on
What happens & when: Had removed the front cover panel, in the process the top panel on the door fell and hit the floor. There is no obvious signs of damage. After reassembling the door the dishwasher will not turn on when pressing the power button. I know that there is 13 volts going to the panel on the wiring harness coming the from power module under the dishwasher. I suspect that the control panel got damaged when it fell. Just want to confirm that is the most likely cause of the problem before ordering the part.
Parts or tests already tried: None
