Dishwasher will not heat water
Dishwasher not heating water for hi-temp wash or sanitize cycle. Also element not heating up for drying cycle. Replaced element but still not working. Any suggestions?
Replacement parts for FRIGIDAIRE GLD2250RDQ0 Frigidaire/dishwasher | AppliancePartsPros.com
Here is a tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154526501en.pdf
Did you check the hi-limit thermostat?
No I have not checked that. Can you provide the part number for the hi limit thermostat? Is it the one under the tub? There is also something called a thermister.
Will appliance parts pro allow me to return the heating element I just ordered? That was not the problem.
AP2109201
Item 29 in Section 3
Yes
It measures the temperature. I am not sure whet it’s resistance should be.
Perhaps someone lse can provide that info.
I do not know.
But I would get a meter so you can check parts before ordering them.
