The dishes are clean, but they are not completely dry and sweat remains on door and bottom and sides of dishwasher after cycle is done.
Here is a tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208524517.pdf
I would check that the vent is opening.
If not, check the vent actuator for continuity.
Also check that the unit is draining properly, if water is left in the tub it cannot dry the dishes properly. Could be just a partially plugged drain.
If you use heated wash cycles and the machine runs normally the heating element and the high limit thermostat are probably OK.
If not check the heater for resistance and the thermostat, see the tech sheet.
