Hi. I need a schematic for this unite so I can trouble shoot a control problem If someone has a hyper link or address where I can get one Thanks
Here are the parts
Replacement parts for WHIRLPOOL GU1100XTLQ1 Undercounter Dishwasher | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
Thanks a lot Denman . saves me a lot of work . Maybe I can do the same some day Have a Good one onerockman
[quote=denman;163775]Here are the parts
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf[/quote]
You are welcome.
[COLOR=Blue]Maybe I can do the same some day[/COLOR]
We can always use a hand at answering questions, thanks.
I got it working Yesterday. Do not Know why? Did full ohm check on ribbon cable. Also continuity thru all pin connectors. Figure I got lucky, all reading were good. Had tried cleaning all contacts earlier with no success. Just one of those electronic bug a boos Maybe it holds maybe not. Thanks again.
[COLOR=Blue]Maybe it holds maybe not. Thanks again[/COLOR][COLOR=Blue]
[/COLOR]
You are welcome.
I have had lots of experience with faults that disappear on their own.
In my case the ones that never returned seemed to always be in town.
The ones that returned were 600 miles north in some God forsaken mine site.
Such is life!!
