My dishwasher had been acting a little funky (some buttons didn’t work, some did) then it went totally dead. I replaced the main board and it came back to life, but some of the buttons work intermittently and some not at all. For instance, I have to set the timer to get the machine to run! Am I looking at replacing the pcb behind the touch pad? Help! My wife is complaining of dishpan hands!![]()
Here is your parts breakdown.
Replacement parts for FRIGIDAIRE PLD2850RDC2 Frigidaire/dishwasher | AppliancePartsPros.com
Here is the tech sheet for this unit
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154493101en.pdf
See Section 1.
Item 3 is the control board, I am assuming this is what you replaced.
Item 8 looks like just a display board so I doubt it is your problem.
Item 2 insert is the keypad, this is the likely culprit.
You could try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
