Dishwasher unresponsive
Hello all,
I am hoping I may get some direction on how to proceed.
I have a Bosch SMU4056; and until recently, it has been a great performer.
The washer was working great and then one day it just stopped in the middle of the wash cycle.
If I cycle through the different cycles it does nothing. There is no sound, no pump noise. Nothing.
I used a shopvac to get the water out of the unit.
I am not sure how to proceed to troubleshoot the unit. I have not been able to find much of anything on the internet for test procedures.
Any direction and help woul dbe greatly appreciated.
Thank you in advance,
Randy
Hi Randy,
The first thing I would do is check for 120 VAC to the dishwasher.
Remove the toe panel and check the power cord connection to the dishwasher for burned wires and/or lose connections.
Remove the outer door panel and check all wires inside the door.
Check the “on-off” and the door switches.
Here are the breakdown diagrams and Replacement parts for BOSCH SMU4056 UC/09 (FD 7307-7902) | AppliancePartsPros.com
I will verify the voltage when I get home tonight. I had the thing apart last night but had no clue where to check, and what to check.
I’ll start with the voltage and wires.
Thank you for your help!
I checked the incoming line and the power coming is 110v; so that is good.
I checked the voltage at the lines coming in to the Selector Switch Assembly and the voltage is still good. From there, I am not too sure what voltages should be - and where.
The odd thing, and I don’t know if this is norl - I cannot remember - is that then the door is opened and the on/off switch is depressed the light comes on (for behind the on/off switch) but once the door is closed - the light goes out. Very odd.
I noticed that the motor for the timer unit is not turning. From what I can gather it is not getting power (?)
I did not get a chance to yank the unit out from under the counter top. That will be tomorrow.
The I guess I can check the other components.
