Thanks a lot for all the detailed information - that’s really helpful. Based on the symptoms, I suspect that the thermal fuse may be the culprit, because the breaker seems OK, and I have no reason to suspect that the DW somehow disconnected from the house hard wiring at this point.
Weird thing about the thermal fuse, though - the diagram seems to show that it’s part of the control panel assembly, yet I cannot find it anywhere. Is this fuse assembly buried somewhere down deep in the door? I started to take that off, but it looked like I risked cracking some of that sound-dampening foam stuff down in the door itself if I took it too far.
Thanks.
[quote=denman;159465]Here are the parts
Replacement parts for WHIRLPOOL KUDP01DLBS6 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208564549.pdf
Could be a number of things.
First check to be sure the connection to power is OK re: usually wire nuts.
Also a good idea to check that it is getting voltage. Otherwise you could rip the whole thing apart and perhaps it is a bad circuit breaker.
Next on the list would be the thermal fuse Item 6 in Section 2.
Next would be the door latch switches but I believe the unit/controls are still live with the door open.
[COLOR=blue]Dishwasher worked fine since then - except some of the cycle lights wouldn’t light up, even though the buttons were functional.[/COLOR]
Unfortunately the tech sheet does not show the wiring for the LEDs so it makes it difficult. Is it possible that you hooked something up wrong. re: the ribbon cable etc.. I do not know if the cable is keyed so that it only goes in one way.
[COLOR=blue]However, even though it sat idle all day, and worked last night, nothing works. No lights, no functions, no nothing.[/COLOR]
This is a bit of a puzzle as the thermal fuse should not blow when the unit is just sitting idle. Note these fuses are know to be a problem and that is why there is a modification fix/harness included with it.
[COLOR=blue]Flipped breaker a few times.[/COLOR]
Try flipping it and leaving it off for half an hour or so. I am not sure how long it would take this board to reset. I think this would be a long shot but worth a try.
[COLOR=blue]Is this an indicator of a failure of some other major component, since the Control Panel is now brand-new?[/COLOR]
Could be
[COLOR=blue]Or is it time to get out the Yellow Pages and call the repair guy?[/COLOR]
Cannot say but if you decide to try and fix it yourself I recommend you get a meter. This will let you check power and also continuity of the connection etc.[/quote]
