Brand: GE
Model Number: Gdp665synfs
Main Symptom: Top Arm Won’t Spin
What happens & when: I have a GE Gdp665synfs. The top arm will not spin. I am not a loss. I have replaced the diverter valve, water fill valve, and pressure sensor. No luck. It seems to be low on water. If I add some water to the tub, sometimes (not always) the top arm will work. I figured the fill valve and pressure sensor would correct the fill issue. Any ideas? Thank you!
Parts or tests already tried: Water fill valve, diverter valve, pressure sensor
