Dishwasher thermal fuse
Just bought a new heating element and it comes with a new control panel. Upon installing the new panel, I discovered the fuse was “blown”. There is some minor sooting around the fuse. The fuse is G4AM1102. Is this common and does the new board fix the issue of this fuse overheating? Can I purchase this fuse from APP?
[COLOR=“Blue”]Is this common and does the new board fix the issue of this fuse overheating?[/COLOR]
It should. I believe the following applies to your unit.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/d12cd4888abce86285256a42005ea985/3647278851c2e3a885256fb800547ae6/$FILE/8178479A.pdf
[COLOR=“Blue”]Can I purchase this fuse from APP?[/COLOR]
Yes.
Replacement parts for WHIRLPOOL KUDS01FKSS0 Dishwasher | AppliancePartsPros.com
Take a look at Item 6 in Section 2.
Be sure to use the new harness that comes with the fuse.
