HELLO im having proublems with my dishwasher it is stuck in the normal light position iam pressing the start and it will not start.
Did you try to cancel the previous cycle?
What is the status of all lights on the control panel?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDI01ILWH1 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Yes, I tried cancelling the cycle. Light is still blinking. For almost 5 days it was stuck on the rinse cycle. Press the energy saver lock button for 4 sec. The light went of the rinse cycle but it was still stuck when I tried to wash. Then the following day I came home from work and no lights were on the control panel. I pressed start and it starting working, it was fillng up with water , then I pressed cancelled and now it doesn’t start, now it stuck on the normal postion and it wont wash. I remains on normal position.Thank you
[QUOTE=Gene;406091]…What is the status of all lights on the control panel?..[/QUOTE]
You missed one question.
What is the color of the control panel?
sorry i couldn’t get back to you sooner, and i appreciate all your help. the color of the control panel is white
when i press the start cycle the normal green light blinks but nothing happens.
Sounds like the problem is a stuck key on the console. The correction is to replace the console.
- The console AP6012899
Thanks Gene, you have been a very helpfull.
