Dishwasher stuck in wash cycle
Kitchenaid Dishwasher model# KUDI02IRBL0 is stuck in the wash cycle. It keeps repeating the wash cycle over and over and wont go to drying. It will fill, wash, and drain then repeat the process. The only way to stop it is to press the cancel button. It drains and stops. It did this for over 2 hours on 2 separate occasions today. Also, the heated drying and 4 hour delay buttons will not light up on the touch pad. All other buttons work fine.
Any help would be appreciated. JD.
On the parts page, I would be temped to replace numbers 1 and 11. Because, it sounds like you have two problems.
Ardvaark
