Dishwasher stuck at 39 minutes
My dishwasher gets stuck at 39 minutes. Called repairman. He replaced computer board. $200. later, and it does the same exact thing. Repairman came back. Said he doesn’t know what else it could be. He left. Now, I’m out $200., and my dishwasher still doesn’t work. After looking online, this is obviously a common problem with this dishwasher. I’ve spent hours reading repair blogs, but haven’t found a solution. HELP!:mad:
Replacement parts for Whirlpool GU2700XTSB1 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Sounds like something is hanging up the cycle.
Try different cycles that do not use certain options/parts to see if you can narrow it down.
At the top of my list would be the soil sensor, though the heater circuit can cause sinilar problems but usually it just extends the wash time.
Here is a manual. You may want to join the site as it is a good site for DIY appliance manuals.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=233
Although not an exact match for your unit it should have info that may be helpful.
GU2700.pdf (244.4 KB)
