Based on previous posts, i suspect a blown thermal fuse is the cause of my DW stopping mid-cycle with water in bottom and now there is no power/lights, etc. Is the appropriate next step to test the fuse for continuity to confirm the diagnosis? If so, i just need to confirm which part exactly is the fuse. Is the fuse unit as shown in the bottom center of the attached pic where the black wires come into the tan wire clips which attach to the black and grey plastic housing? if that is not the fuse, is it visible in the pic?
awesome, thanks for the prompt reply! i was not sure how to remove the bone-colored housing as shown in the attached pic so i just put my test leads on the exposed metal prongs - no continuity detected. Was that a valid way of testing continuity or do i need to get that housing/wire harness thing off? image.jpg (32.3 KB)
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
