My name is Garrett. My dishwasher smells like something is burning the last 2 times it has run. It has always had a problem with the soap dispensor opening when it runs. The electric is also a little touchy as the power cord was just long enough to connect, so sometimes it loses power for a second. Any ideas on why it would smell like burning when it runs would be much appreciated.
Garret,
The first thing you need to resolve is, your power supply, Loose connections, fluctuating power , etc. create all kinds of overheating, low or high wattage problems etc. You really need to solve that issue first. A short, heavy duty, extension cord or a longer power cord may be a easy method to solve the issue.
Make sure the dishwasher is filling properly on all cycles, It could be the water heating option trying to heat the water, and theres none there. Otherwise we’re back to possible damage to electrical components, due to the power supply issues.
Thanks and Good Luck,
[quote=Joe / APP Team;542243]Garret,
:)[/quote]
Thanks for the advice. I got a chance to look at it and the hot wire had been taped on to hold it tight because the screw holding the hot wire was stripped. It was duct tape and it was burning. That was the smell. So i removed the duct tape and put a new screw in to hold the hot wire. I ran the dishwasher and there was no smell. Thanks for your help.
Glmy,
Great job,
We’re glad we were able to assist.
Hopefully, all will be good from here on out.
Good Luck,
