Dishwasher repair
Brand:Bosch
Model Number:SHP65TL2UC/09
Main Symptom:will not turn on
What happens & when: when I hit the On switch, nothing happens.
Error Code (if any): I did have an error code 15. The dishwasher was leaking water so the float switch was activated. I removed the water from the float bowl and dried it out. Now the dishwasher does not turn on.
Check your breaker to make sure it did not trip. Follow the voltage trail, where is the voltage going and then stopping?
I have no trouble with the breaker. I will try to follow the voltage trail. Just before it stopped working, I had an E15 message. I did empty the float bowl and dried it out. I thought I had solved the problem but now it will not start. No lights at all.
So I followed the voltage trail. From the the wall receptacle to the control module, I definitely have power. All the wires that leave the control module have power except for 3 red wires that I believe go to the start switch on the control board. Also 2 yellow wires that also go to the control board. All of the other components have power.
With the power off, check continuity through the switch. I don’t have a wiring diagram, there should be one on your DW.
I do have continuity going to the start switch. I also have continuity going to the on/off switch. I have power going to the dishwasher and power running throughout the dishwasher, yet no lights on the control panel. What could possibly cause this?
I hate just throwing the word control board out there, but I don’t know of anything else that would cause the DW to not come on.
