Help! My dishwasher keeps filling up with hot water, even after I shut it off!:eek:
You probably have a bad inlet valve if it keeps coming in after you shut the unit off…if it keeps coming in only when the unit is on check the float switch for continuity.
dishwasher inlet valve testing - YouTube
dishwasher float switch testing - YouTube
Parts
Parts for GE GSD500D-03AW Dishwasher - AppliancePartsPros.com
[quote=HumboldtRepairMan;828974]You probably have a bad inlet valve if it keeps coming in after you shut the unit off…if it keeps coming in only when the unit is on check the float switch for continuity.
Parts
Parts for GE GSD500D-03AW Dishwasher - AppliancePartsPros.com[/quote]
Thanks, that’s what we figured it was. The water inlet valve. The Youtube videos will be helpful.![]()
Hey! Come to our website. I’ve recently come across fantastic traitement de l’acné
