My Bosch dishwasher SMU2042UC/14, series 2000 sequence monitor dial sticks in the wash cycle and the rinse cycle. I replaced the control with a new one but had the very same results as the old. What do I try now?![]()
If the dishwasher fills correctly then stops running, suspect the timer mechanism or circuit board. Be sure to try every available cycle. If no cycle runs, your timer has probably failed. For a little more insight to possible solutions, here’s a quick and easy read that might help: [FONT="]Dishwasher won’t start.
[/FONT]
