The start/ resume and cancel buttons on control panel are not responding and machine will not work. Other buttons on control panel work
Replacement parts for WHIRLPOOL KUDK03ITWH0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
See the second page in the tech sheet for the keypad matrix.
The two bad keys use P1-12 as a common but there are other keys that also use this line so check if they are working.
The problem can be caused by the control panel (keypad) or the control board.
The usual way to trouble shoot this is to check the keypad with a meter if it checks out OK then replace the control board.
Still a bit of a crap shoot but your odds are better.
If the other keys using P1-12 also do not work you may want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
DU1055.pdf (251.2 KB)
