You wrote:
It does sound like the panel (keypad), Item 1 in the “Control panel” section is going.
The tech sheet shows how to check it with a meter.
Could also be that one of the door switches is just making and pushing on the panel shuts the door enough to activate the switch.
I would try the following first in case pushing hard on the panel is moving the ribbon cable enough to get the unit going.
Unplug the unit
Open it up
Clean the edge connector.
Did what you suggested, I can’t help thinking the door latch may be involved because all prompts work on the control panel with the exception on the start. The start will work if I open and close the door a few times and push very hard on the start. Do you still suggest replacement of the control panel or could this be the door latch??
