Dishwasher Repair – Leak, No-Wash, Error-Code Help
Leaks, poor cleaning, or will not start? Ask dishwasher questions here.
Post title must be: brand + full model number + main symptom
Example: “Bosch SHX68T55UC leaks under door”
Body checklist:
• Cycle chosen and where it fails
• Water hardness, detergent type
• Service sheet error codes
• Photos of sump, float switch, or seal
Before posting, run a quick search in this forum to see if your issue is already solved. If you suspect a bad part, paste the exact AppliancePartsPros.com product URL so others can confirm it fits your model.
KitchenAid KDTM354DSS0 tub is not filling. I replaced the inlet water valve and it started to work normally, but it stopped filling again. I am suspecting the control board is causing the water inlet valve to fail and needs to be replaced. I would like to get a technician’s opinion on this.
