Dishwasher probs
My d/w doesn"t receive water anymore, It will run through the complete cycle, including opening the auxiliary detergent reservoir for the second cycle. The washing arm wasn’t moving w/out water. I manually added some water and the arm and every thing worked, but it would not drain at the end.
I thought - pump - but water would flow through the arms when I added it.
Does the unit have two pumps?? I don’t want to just start replacing things willy nilly. Could it just be a switch?? Is there anything definitive that it could be or could it be any of numerous things??
Any ideas??
Make sure the float inside is not stuck up as that would keep it from filling.
