Dishwasher problems
I have had this dishwasher about 2 yrs. When I push start button, the drain/cancel button lights up and goes through cycle. I will then press start and the same thing happens everytime. I flipped the breaker and waited a few minutes, pushed start button and same thing. HELP:(
Most likely the problem is a shorted key on the control panel. If you need the correct part number post the color of the control panel.
Here are the break down diagrams and Replacement parts for WHIRLPOOL DU1145XTPB6 | AppliancePartsPros.com
Here is a tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535451.pdf
It has info on the keypad output.
Check it with a meter for a stuck key etc.
