Dishwasher not starting. “SMART WASH” and “NORMAL WASH” buttons blinking. Already unplugged unit for 10 mins, and also checked circuit breaker.
Most likely the problem is a stuck key on the keypad. The correction is to replace the control panel. If you need the correct part number, post the color of the control panel.
Entire DW is beige (bisque).
The bisque control panel AP6013090
