Dishwasher not responding to the start button
I have a wdt730hamz1 dishwasher that is not responding to the start button. I did check the door switch and appears to be fine
Hi, if the Start button isn’t working, you may have to replace the control panel. Before replacing it, though, I would open it up and check for any corrosion. Also, inspect the ribbon cable for any dirt or debris and clean it if needed. Sometimes a poor connection there can keep the Start button from responding.
This dishwasher has all the button on the control panel as one assembly. Is the only safety switch being the door switch?
yes that’s correct sir
