Opened dishwasher after wash cycle. Soap dispenser open, but soap not dissolved. Dishes not clean. Noted kitchen faucet barely working. Apparently a slug of soft sludge got in water line. Flushed water lines at sink. Removed copper tubing at inlet to dishwasher (DW) and found sludge at inlet filter going to I believe the solenoid valve.
Cleaned inlet filter. Replaced copper tubing with SS flex house. Flushed flex before hooking up to DW - solid stream of water with good pressure. Hooked up to DW and tried to run. No water going in to DW.
Wondering if I should replace solenoid inlet valve? Or is there something else I should try?
Thanks, Jim
