Dishwasher not filling with water
Problem: the dishwasher was not filling with water.
What I did: 1) checked the water line to the water inlet valve - OK. 2) verified flow of water through the inlet valve - OK. 3) checked the line from the inlet valve to the tub - OK. 3) Put back together, fired it up, working fine, but then the water stopped flowing again. 4) took inlet valve apart - looked in reasonable order, cleaned out all the grit, reassembled, fired it up, working fine, but then the water stopped flowing again. It works at the beginning of a cycle, but does not continue to work throughout the cycle. Once it stops working, starting a new cycle does not make it work. It’s almost as thought the switch was overheated or something. I let the unit sit for an hour and restarted and the water flowed fine - but again, did not last until the end of the cycle.
Replacement parts for WHIRLPOOL DU8500XX0 | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203370466.pdf
To troubleshoot this effectively you will need a meter.
Measure across the water valve when it should be filling and it is not.
If you have 120 volts then the valve is toast and needs replacing.
If no voltage
Measure across the overfill switch
If you have 120 volts then either the float is not actuating the switch or the switch is toast.
If no voltage across either component .
Then you either have a loose connection, a wire that is broken internally or the timer is toast.
Just be careful when measuring voltage.
The following is just for future reference
