I have a Kenmore Elite Ultra Wash Dishwasher. It is about 4 years old. It worked fine for about 3.5 years. Then the soap dispenser would start having soap left in it and the dishes would not clean, especially the top rack. I paid a local appliance store to come and repair and after 1 hour, they could find nothing and only suggested me spending $300 to replace the pump/motor. I said “no.”
I finally hopped on line and read various forums. After tearing the machine apart inside (chopper, check valve are fine), I put it back together one piece at a time and checked the pump pressure (by opening the door quickly) after every piece assembled. The pressure looked good until I installed the riser that feeds the upper rack and the upper rack itself. It did not seem like sufficient water was making it up there. I placed two cutting boards on the bottom rack to block the bottom spray completely and found out zero water was reaching the top rack. However, the tubing was clear all the way to the top.
I noticed the pump/motor sounded like it was surging and the level in the bottom looked kind of low. I thought maybe the pump was being starved and the pump was cavitating. I added about 3 quarts of hot water, until it hit the high level float. Then the pump quit surging (cavitating) and I had a waterfall coming off the top rack. Not enough water. Okay.
I disassembled the inlet valve and cleaned it out. There was some black particulate coming out of my hot water pipe so I ran about 20 gallons of water until it ran steadily clear. Found some of this black stuff in the valve. There was a lot of pressure coming from the hot water, so it was not low water pressure.
After reassembling the inlet valve and running, it still had the same problem. I thought maybe the internal workings were plugged with the black stuff so I ordered a new inlet valve. Then, the next day, before the new valve arrived, the darn thing worked normal! I thought maybe some particulate finally broke loose. It worked several times in a row. But, I also noticed the water fill was running longer … 2:50 (min:sec) compared to about 1:45 previously. Longer fill time means more water.
Today, the problem is back, and I’m back to 1:45 fill time. What the heck?! A bad timer? My tech sheet that came with the machine says “some models” have flow meters that can be the cause of this (I guess if the meter senses a higher flow rate, even if it is inaccurate, it will turn the water off earlier?). But going to the Sears/Kenmore site, it does not appear my model has a flow meter.
(New edit to post on the next day … last night, I reset the system to factory defaults (in case it was “confused”) using keystrokes “Heated Dry >> Normal >> Heated Dry >> Normal” and let it go through its cycle … it still did not work properly. I woke up this morning and it is back to running properly … I ran it three times today, all successfully. Did I say “intermittent”? What will tomorrow bring?
What next? I am hoping to stay away from appliance repairmen … already one bad experience and waste of money that could have been a lot more expensive. Your help will be appreciated. Any thoughts, please?
walterw
