Dishwasher not drying
dishwasher works fine otherwise just that dishes are wet and not very warm at the end of cycle. not drying them for some reason. it seems to heat the water fine during the wash cycle. when it goes into the dry cycle there isnt much heat coming out of vent. anyone have any ideas whats wrong.
Replacement parts for Whirlpool KUDI01ILBL1 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
If you are sure that the water is being heated then odds are that the control board is shot.
If you are not 100% sure try running the diagnostics.
Unplug the unit and check the heating element (about 20 ohms) and tghe hi-limit thermostat (0 ohms).
KUDI01.pdf (970.8 KB)
thanks for the info.
