Dishwasher Not Draining
A friend recommended this forum because the advice helped them. The great advice helped me when I first experienced a draining issue with my dishwasher.
When I first experienced drain issues I followed the instructions in this great post - [COLOR=#0066cc]http://forum.appliancepartspros.com/dishwasher-repair/16487-ge-profile-dishwasher-wont-drain-completely.html[/COLOR] - but unfortunately it is not working this time.
I checked the sump then performed the reset test after letting the washer fill. The pump activates and water drains initially, but then you can hear a valve or something close and water stops draining. The timing of the valve closure varies from almost immediately to a few seconds. The pump continues to run for a minute or two.
I also went in to the service mode to isolate and activate the pump. Again, the pump activates and water drains initially, but then you can hear a valve or something close and water stops draining. The timing of the valve closure varies from almost immediate to a few seconds. The pump continues to run until I deactivate it. I used a shop-vac to remove the standing water. Shy of calling a repairman, I am out of ideas. Any advice, suggestions or recommendations is much appreciated. Thank you.
I’m having same problem dishwasher won’t drain. It’s a GE Quietpower1. First it wouldn’t go thur it’s cycles, but now it is but it want drain.
Please Help
