I can’t see anything clot it out side of the screen. I don’t know how to removed the screen to see inside. A little bit of water stay inside the Dishwasher. Any suggestion?
:mad:
WHIRPOOL DU800SWKUO FL 3121637
TYPE 280-0
:mad:
TYPE 280-0
Replacement parts for DU800SWKUO models | AppliancePartsPros.com
Here is a service manual for a DU800 series, yours should be close.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/56e33eb0e839a7fa85256a8e00510938/$FILE/4322430.pdf
First check your drain line and house pluming for a partial plug.
One area that can be a problem is where the drain hose goes over the fitting into the house plumbing.
If OK then I would take the pump apart.
